David Shorter
bug in 19 8000
I needed to check something for a colleague
It involved creating a sun study using the 2DL output from the 3D window
Unfortunately saving shadows at 9am 12 and 3pm produces 3nfiles each with exactly the same shadow.
Opening the same file in 20 produces the correct result.
It should be noted the there are user still using version 19 so this is a critical issue.
ps
I just checked the option to create PMK files but these have the same issues. I create 3 PMK files and they show exactly the same shadow.
Just to make matters worse, copying and pasting from the 3 D vectorial window produces the same incorrect shadows.
The only view which creates a correct sun study shadow is the 3D document window.
This is not impressive
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
0 Replies 0
