Installation & update
build 1200
just downloaded and saved latest "fix" (build 1200).
closed all apps. Run file. Rebooted. Launch AC11---
Following error message:
Sorry, ArchiCAD cannot run on this computer.
Problem: ArchiCAD could not be launched because the following add-ons are
missing:
Interactive Schedule
In order for ArchiCAD to start, these add-ons must be placed in this folder:
C:\Program Files\Graphisoft\ArchiCAD 11\Add-Ons
So, i did as instructed and moved Interactive Schedule from C:/Program Files/Graphisoft/ArchiCAD 11/Add-Ons/Standard to C:/Program Files/Graphisoft/ArchiCAD 11/Add-Ons
Rebooted and tried to lauch AC11 numerous times--same result.
Anyone got a clue?
4 REPLIES 4
Thomas Holm
Archidog wrote:
Anyone got a clue?
You're moving files from \ to /. Dog's work, apparently.
syntax?
never understood the punchline
Thomas Holm
Archidog wrote:
syntax?
Sorry. It's the date, mate! (Check your original message)
And I think the only true cure is to re-install Archicad 11 from the original CD and then re-apply the update. If anything has gone wrong during the update, whatever you do otherwise might end in some mixed-up half-breed state.
JaredBanks
Mentor
I had this same thing happen to me today. I think I moved add-ons from a 1114 build on OS 10.4.11 to a 1114 or 1200 build on OS 10.5 (don't know the build because now I can't open the damn program). Going to have AC11 reinstalled. Not impressed.
Jared Banks, AIA
Shoegnome Architects
