can't install please help someone...
Hi Everyone...not a newbie...but problem installing this EDU ver of Achicad 10....During unpacking the install goes to "Windows XP Setup" Dialouge box. It tells me to go to control panel and configure system components? What the heck does this mean? I'm on WinXP Home SP2.
Any help would be greatly appreciated.
NOTE: I've tried making a new user and same problem comes up. Also tried installing in safe mode. Downloaded 3 different copies all the same results.
Thanks.
Tom.
Djordje
Thanks.
Tom.
Dd you run Windows update recently? It sounds like you don't have all the system components that are required. Also, do take care that, Home or Pro, you HAVE TO install Archicad with moderator access right.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
