If you only plan to use as a reference, may I suggest drag and drop onto an independent worksheet. Then, set the worksheet as a trace reference.
If you want to edit the DWG in the model, you can Edit, Reshape, and Explode into Current View. This will present an option to import the DWG layers or have all onto your designated AC drawing layer. The benefit of the first is to give you the most modeling versatility. An advantage of the single layer option is keeping your model file free of the DWG layers but still having editable DWG elements in your model.
There is some further thought by myself and others in another post:
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=69579#p309995 which may help inform.
Hope this helps.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
