edit color crashes archicad every time!
every time i use edit color in pens&colors panel, archicad crashes...
...no reason, or at least i think so...
also, same thing happens with versions 7.0, 8.0 and 8.1. so i don't tink
it is so much program erelated as much with system.
i run windows 2000 profesional
cpu Intel pentium IV 3,066 Mhz
ram 1 GB
HDD 2x30 GB 1x40 GB
GC 3Dlabs WildCat 970 with 128 MB
does anyone knows how to fix this?
pls help!
3 Replies 3
It sounds like a problem with the system color picker. Do any other (non-GS) programs have this problem?
You may need to repair/reinstall the system.
I remember once we had someone with his AC crashing when selecting the Tools menu. It turned out to be a graphics card problem.
Just an idea.
Laszlo
We're currently running the GForce 9200, 128mb card, it's not bad but wasn't installed properly. It would blur slighlyt in 2d and anything more complex than the orchard project in 3d (from the examples folder) would bomb out. Could be the graphics card, could be you need to try a reinstall on your AC.
