error .pln file
please I need help. I work on project in Archicad, bat shutdown me energy. When starts computer after 10 minutes and I reopen project. Computer write me, error when loaded file because file is crash... I need this file reopen because it is abou 1 mount works on it. Sorry, me English isn´t good 🙂
Thanks Tonda
Thanks Tonda
Dwight
If you do not protect your data, you will lose data when the power goes off.
Did you have AutoSave turned on?
Did you have "Always make Backup copy" turned on?
If so, then look for a file with the name of your project file, but extension ".bpn."
Open that and see.
Good luck.
Dwight Atkinson
-Auto save I have on.
- bpn file i found but this file have the same problem. Don´t open too.
Eksists any recovery utilities? or have I big problem and will be make this onemore?
Today I order Ups.
Thanks for answer
