Installation & update
install Archicad 10 file converter
RandyC
Archicad 10 file converter does not work without having Quicktime installed
Apparently it was last used in version 17 archicad
Apple has discontinued windows version
so how or where can I get a quicktime installation file - so that I can install the file coverter ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Google, and use a trusted site for download? I installed QT last fall to get the file converters to work with Windows 10 (thanks, Barry). Can't recall what site I used, but this one is probably reasonable:
https://downloads.tomsguide.com/QuickTime,0301-31.html
RandyC
Thanks, I will try that site although there is lots of buttons to press that download other things.
The internet is a dirty place - Graphisoft should supply a link to a safe download site with the file coverters
vistasp
Try this link:
https://support.apple.com/downloads/quicktime
Maybe we Windows users should archive a copy of it, in case it disappears at some stage from the Apple support site.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
