keyserver problem
hi.
we have a network with a keyserver. all was working fine with archicad 8.1, but with archicad 9 the problem is that the computer where the keyserver is installed cannot run archicad. I watch the keyserver software log and found a problem:
3.15 13:37:48:710: Error - WkbOpen2(): Invalid handle specified.
i tried to install the most recent driver of wibu, but the problem persists.
I suppose the problem is archicad 9 because archicad 8 works in this specific computer (the one where is keyserver).
Thank you for any help
6 Replies 6
Ben Odonnell
Hi there,
Are you on PC or MAC?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
I´m on PC.
Can you help me?
Thank you.
Ben wrote:
Hi there,
Cheers.
Ben
I'm on PC. The problem persists...
Ben Odonnell
Is the key plug upgrade to work with ArchiCAD 9?
Cheers.
Ben
Ben O'Donnell
yes, the key is upgrade, it works. The problem is on the computer where the key is physical attached, archicad dont recognize the key as valid (i saw the error on wibu log). From any other computer on the network it works fine.
thank you
Cheers.
Ben
Gorazd
When I was trying to run ArchiCAD 9 on single computer with NET keyplug, it didnt work also. I have folowed the instructions on WIBU CD which says:
"On a standalone computer ArchiCAD doesn't recognize the NET WIBUKEY.
Workaround:
Set the server's IP address on the Start menu>Settings>Control Panel>WIBU-KEY program >Network tab page to 127.0.0.1. "
Maybe this will work for you too.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
