macOS Catalina and ArchiCAD 23
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-09-20
02:00 PM
‎2024-01-31
01:43 PM
Aruzhan Ilaikova
Question: Since ArchiCAD 23 was released on the same day as macOS Catalina [edit: I see now Catalina will be released in October], (and was three-months behind standard release date, maybe benefitting by utilizing developer copies of Catalina), my question is:
"Will ArchiCAD 23 be compatible with macOS Catalina?"
...or at least, more so than usual? There is usually the dreaded do or die warning to not update the macOS generally until December or so. @LaszloNagy any word?
Thanks!
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-18 03:10 AM
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-18 07:36 PM
Cheers!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-19 04:48 AM
spodonahue wrote:.
UPDATE: I don't know if this will help anyone, but this is the response that I received from GraphiSoft this AM, they sent me this linkhttps://gsoft.link/macOSCatalinaAdvice. However, when specifically asked if the release is reasonably functioning they didn't answer the question, other that AC 23 was "designed with Catilina in mind". It seems like a non-comittal answer to me. Also, some official correspondence on the ArchiCAD site say "wait for 3 months"... others say "wait until spring". I'm assuming that the latter means wait until the AC 24. I'd love to hear if anyones else has made the jump and what their experience has been.
Cheers!
I share a coworking space with a colleague (we're each sole proprietors) who runs ArchiCAD 23 and Catalina. He says he has ZERO problems so far and he uses it every day. I still have many clients (I consult) using v22 so I have to stay in Majove for a while longer or I would probably upgrade to Catalina.
I think you really have no choice but to "Go For It!" Good luck and please let us know how you do.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-22 06:27 PM
If you have several Macs to upgrade, perhaps pilot an upgrade on one of them?
Note: In reading up on Catalina, the 64-bit standard is set high, so older software is on its own. I did find Paragon has an NTFS version for Catalina (Windows to Mac flash drive compatibility), as does Sophos (AV) Also, if I read correctly, Catalina has a CD media reader, (e.g, read old drawing archives).
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-23 01:36 PM
Otherwise I met often the stop for about ten seconds of the Arrow it doesn't works until passed that short time.
Nothing more.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-24 11:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-03 02:22 AM
Rex wrote:After reading the responses from others, I went ahead and did it and made the first jump on my MacBook Pro. So far so good, I only had one instance where AC23 wouldn’t hold my profile for custom menus/tool pallets, but after a re-boot everything appears to be fine.
spodonahue wrote:I share a coworking space with a colleague (we're each sole proprietors) who runs ArchiCAD 23 and Catalina. He says he has ZERO problems so far and he uses it every day. I still have many clients (I consult) using v22 so I have to stay in Majove for a while longer or I would probably upgrade to Catalina.
Cheers!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-22 04:02 PM
Please write in English, if not you risk getting banned since that is a requirement to post in the forum.
Translation:
No other software that I own (the entire Adobe suite of ongoing processing) is so threatened by OS updates. It becomes frustrating.
AC28 US/INT -> AC08
another Moderator
- « Previous
- Next »
- « Previous
- Next »
