previous versions
I have student licence to ArchiCAD 19, I want to transfer files from 19 to 16. ArchiCAD can save the file as a version minus one.
I can´t find version 17 to download. I found ArchiCAD 18 and 16 on myarchicad.com, but 17 I didn´t find.
Thank you for help
8 Replies 8
Here is the link to the INTernational version.
http://www.graphisoft.com/downloads/archicad/install/AC18/INT/
Or the Czech version if you would prefer that.
http://www.graphisoft.com/downloads/archicad/install/AC18/CZE/
I am not sure if you can use the same student license for all of them or if you need a different one for each version.
That may be a problem because this may not run as a student version without its own license and therefore may not be compatible with your student files?
I've already had ArchiCAD 19,18,16 from myarchicad.com. And it works.
And I need somewhere download AC 17 to transfer files to AC 16.
For me it's not important how I transfer file, if you know another way.
Anyway I thank for your answer
Sorry I was rushing a bit and copied the wrong links - just swap the 18 for a 17 in the link.
http://www.graphisoft.com/downloads/archicad/install/AC17/INT/
or
http://www.graphisoft.com/downloads/archicad/install/AC17/CZE/
Sorry again those links don't seem to work - only back to version 18 on their website maybe.
If you can't get 17 from MyArchicad (I believe you can only get the last 2 version 20 & 19 unless you have downloaded the others previously) then you will be best to contact your local distributor and they might be able to help you.
OK I'll try to contact local distributor.
Thank you
I found ArchiCAD 17 on myarchicad website: https://myarchicad.com/profile/ac17.aspx
I only rewrote 18 in https://myarchicad.com/profile/ac18.aspx to 17. And it worked.
You can rewrite it to any number of previous versions and download it.
Anyway I thank you for answers.
Thanks for letting us know.
That is what I tried with the links I posted but it stopped working at 17.
Glad to hear you can do it through MyArchicad.
