2009-05-03 01:50 AM
2009-05-03 02:12 PM
2009-05-04 12:55 AM
owen wrote:Ok thanks for the links.
ArchiCAD Wiki - What kind of machine should i buy?
Although AC can still only make use of 4GB i would consider upgrading to the max your laptop will allow (4GB for the 15", 8GB on the 17") if it is within your budget .. you should see a very large general system performance increase - particularly if you only have 2GB atm which is really what i would call the bare minimum you need to run anything these days.
Having said that it is still possible that AC will not be able to handle a large 3D model despite you having enough free RAM. Here are a few more Wiki pages on the subject:
http://www.archicadwiki.com/TechNotes/How%20to%20Control%203D%20performance?highlight=%28Not%29%7C%2...
http://www.archicadwiki.com/LightWorks%20memory%20usage?highlight=%28Not%29%7C%28enough%29%7C%28memo...
