Installation & update
"Save as" pop-up window
Anja1
I have a problem in Archicad 25 on a Macbook Pro. Each time I am saving a file and open the "save as" pop up window this window gets way to big for my screen and I spend a lot of time pulling it across my screen to find the save button or the settings. There is no possibility to pull it smaller at the edges and I haven't found another way to minimize it. I even deleted the program and reinstalled it but nothing changed.
I was wondering if anyone has ever had the same problem or if you know whether there is a solution for this.
Here are some screenshots so you can see what I mean...
Bildschirmfoto 2022-02-01 um 20.31.47.pngBildschirmfoto 2022-02-01 um 20.32.31.pngBildschirmfoto 2022-02-01 um 20.33.15.png
Eduardo Rolon
Known bug, reported multiple times, read here.
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
5 REPLIES 5
Frillex
I got the exact same problem yesterday.. Can't figure out how to solve it..
AC 26, OS MONTEREY
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
Dear Eduardo
You keep posting this link, but it is not a solution.
I have all the latest updates and the problem persists.
@constantinos alexaco wrote:
Dear Eduardo
And it got accepted as a solution.
So it must work, at least for some people.
That seems to be the case with the original poster as they liked the solution.
Have you contacted your local Archicad support people?
That is what they are for and they should be able to help you investigate the problem.
We are all just fellow Archicad users, and can only go by what we read here.
Eduardo Rolon
Also it depends on what AC version and localization if you have 23 and earlier will not have the fix. AC24 update was released later than 25. Also some localizations are updated later.
AC27 US/INT -> AC08
another Moderator
