random crashes Archicad 18 on macbook pro 2011 OSX 10.10.3
I have got a lot of seemingly random crashes of archicad 18 (edu) on my macbook pro (early 2011) with OSX 10.10.3.
Below is the log I get from the apple crash report.
Is there anybody who can understand out of it what actually the problem is?
Or is there anyone with the same experience?
Thanks in advance,
Vincent
 Process:               ArchiCAD [30743]
Path:                  /Applications/GRAPHISOFT/*/ArchiCAD 18.app/Contents/MacOS/ArchiCAD
Identifier:            com.graphisoft.ArchiCAD
Version:               18.0.0 v1 NED [4020] (18.0.0.4020)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           ArchiCAD [30743]
User ID:               501
Date/Time:             2015-03-04 18:26:20.017 +0100
OS Version:            Mac OS X 10.10.3 (14D87p)
Report Version:        11
Anonymous UUID:        0D71FC91-D6AB-729E-C47B-5E6D47E5F819
Sleep/Wake UUID:       30D3D328-2FCC-4591-9523-A085635092D2
Time Awake Since Boot: 64000 seconds
Time Since Wake:       12000 seconds
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       EXC_I386_GPFLT
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libc++abi.dylib               	0x00007fff92d8ea90 __dynamic_cast + 33
1   com.graphisoft.DG             	0x0000000119cb7e25 -[DGMenuController menuItemWithShortcut:inEvent:] + 366
2   com.graphisoft.DG             	0x0000000119cb7ecf -[DGMenuController menuItemWithShortcut:inEvent:] + 536
3   com.graphisoft.DG             	0x0000000119beced6 -[DGController handlesKeyDown:] + 1764
4   com.graphisoft.ArchiCAD       	0x000000010ffd81bb -[AppController sendEvent:] + 134
5   com.graphisoft.DG             	0x0000000119cb2bfe DG::MacApplicationImpl::ProcessSysMessage(void**, bool) + 78
6   com.graphisoft.DG             	0x0000000119bc8a4d DG::Application::ProcessSysMessage(void**, bool) + 25
7   com.graphisoft.ArchiCAD       	0x00000001141fa77c FW::ACApplication::MainUserBreak(bool) + 956
8   com.graphisoft.ArchiCAD       	0x00000001129198bb UserBreakTest() + 61
9   com.graphisoft.ArchiCAD       	0x000000011359697c SL::WasUserBreakWhileRebuild(SL::RebuildEnvirData*) + 95
10  com.graphisoft.ArchiCAD       	0x00000001135b1bfe SL::RebuildCallback(SL::RebuildEnvirData*, bool) + 12156
11  com.graphisoft.ArchiCAD       	0x000000011359ed28 SL::DoRebuild(SL::RebuildEnvirData*, bool) + 259
12  com.graphisoft.ArchiCAD       	0x00000001135976d7 SL::RebuildAll(WM::DrawingWindow*, RebuildRedrawAction const*, bool) + 1732
13  com.graphisoft.ArchiCAD       	0x00000001136029fc DrawFloorScreen(WM::DrawingWindow*, RebuildRedrawAction const*, bool, bool) + 207
14  com.graphisoft.ArchiCAD       	0x00000001136035c2 AfterZoom(WM::Window*, RebuildRedrawAction const*, bool) + 626
15  com.graphisoft.ArchiCAD       	0x00000001136031ca ConditionalRedraw(WM::Window*, RebuildRedrawAction const*, bool) + 490
16  com.graphisoft.ArchiCAD       	0x0000000113614ecb ConditionalRedrawer::Do() + 4777
17  com.graphisoft.ArchiCAD       	0x000000011408a2ef FW::ACApplication::ProcessACEvent(FW::ACEvent const&) + 2375
18  com.graphisoft.ArchiCAD       	0x00000001141fa05b FW::ACApplication::MainMessageLoop() + 2037
19  com.graphisoft.ArchiCAD       	0x00000001142be7f7 FW::Application::Run() + 241
20  com.graphisoft.ArchiCAD       	0x00000001141f9854 FW::ACApplication::Run() + 394
21  com.graphisoft.GSRoot         	0x000000011943dedf GS::Main() + 81
22  com.graphisoft.ArchiCAD       	0x000000010ffd80c5 -[AppController run] + 59
23  com.graphisoft.ArchiCAD       	0x000000010ffd85dd main + 182
24  com.graphisoft.ArchiCAD       	0x000000010ffd8034 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        	0x00007fff94e30232 kevent64 + 10
1   libdispatch.dylib             	0x00007fff97eeea6a _dispatch_mgr_thread + 52
OS 10.10.3 is a (public) beta release, so I don't know that you should expect your day to day work to proceed normally.
You'd have to contact GS tech support for Belgium to have them investigate, should they be testing 10.10.3 themselves.
(It looks like the crashed thread is saying that there was a user break - pressing the escape or period key perhaps? Do you have any external input devices connected to your macbook pro if you yourself were not pressing any keys at the time of the crash?)
Thanks for your reply!
I didn't have an external input device connected at the time it crashed this time.
I do use shortcuts and escape a lot though so it crashes only then.
I know I'm using a beta (which maybe isn't advisable) however I have this problem since I'm using Archicad 18 the past half year on any version of OSX 10.10.x. Its really strange...
