show on story problem
Hi
I’m using Archicad for about 6 years from Archicad 11 till 19.
I Love it.
but there’s problem! I can’t change “show on story” option
when I change it, it revert to “home story only”, it drives me crazy!
or when i chose “entire model” in trace option it shows nothing other than home story!
I don’t know what should I do, I need this feature in stairs, elevator, site plan and etc.
3 Replies 3
David Maudlin
The Entire Model Display is just for showing all when Partial Structure Display... is used, on the same Story. In the Help files see: Views of the Virtual Building > Partial Structure Display > Visualizing the Entire Model. So I think you want to choose the Story you want to see, not Entire Model Display.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David
I didn't get it why my trace doesn't show entire model.
is there any option that show every story below?
and I can't change "show on story" too.
David Maudlin
Not using Trace & Reference. I have not needed to do this, but a few ideas:
1. Overlay plan views on a layout sheet, then use that layout as T&R
2. Use the 3D Window set to Parallel Projection > Top View and 3D Window Settings > Vectorial Engine > Wireframe Mode to see down through the model. The Stories could be limited by Filter and Cut elements in 3D > Stories to Show in 3D.
Maybe someone who has done this will add a comment.
Thanks for adding the signature.
David
