Installation & update
strange openGL problem
hello
i have a new laptop with intel core duo 18GHz
GeForce 8600 GT Turbo
2GB RAM
200GB HDD
when i use arhicad 10 in 3d i it only works in internal mode,
and in openGL the project disappears even if i select only one slab for example. and it only shows up when i click with the mouse button or the pan button and it is visible only the time i have them clicked.
i tried reinstall the program and still nothing, even though the first week it worked just fine.
3 REPLIES 3
Djordje
WENDY_NEVERLAND wrote:
hello
2GB RAM
200GB HDD
Looks like your GeForce is not firing on all cylinders. Try checking its memory, updating drivers ... reducing hardware acelleration ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Paul King
Mentor
I am guessing you are using Vista? driver update will definitely help
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
thanks ill try that
