window default setting
i just installed archicad 13 student version and i found out that inside the window default setting where you have the window builder but instead of window builder setting shows it shows a "window sliding setting" and that goes the same when i select doors it shows "window sliding doors instead of window builder" and it did affect my drawing that had saved from school because i couldn't work further on my drawing because the window directory is not working and it's missing from the drawing. Technically it's there but it doesn't show........i need advise.....
0 Replies 0
