3D Dwg Model Import Problem
I am new to GDL and have come across a problem after i have imported a 3d dwg model from autocad.
The models are importing correctly and are displaying correctly but i want to be able to fix there size, and also there height, as it seems to want to drop in at random levels. in 3d the grip points seem to be well above and below the model.
thanks in advance if you can help
0 Replies 0
