3D text along path or curved
how can i curved a 3d text?
AC 10
thanks in advance
5 REPLIES 5
Dwight
Without buying Cigraph's ArchiForma that places text on an arc, you must do the letters individually.
If the arc is horizontal, make one letter in plan, multiply/rotate the letter into the arc and change each letter to what it needs to be. Rotate again to kern.
As for a vertical arc, it is really one letter at a time.
Dwight Atkinson
www.objectsonline.com/customer/product.php?productid=115800&cat=0&page=1
Djordje
Did not check whether GDL Toolbox still exists, but it had text curving all over.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Rod Jurich
Dwight wrote:
/..... you must do the letters individually.
Or you may share my shared/shared part. Translated and slightly tweaked but you are all free to use. If you require it for 9 PM
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Stress Co_
Make the text into a Linetype? Sans line.... Use the linetype with a spline or arc of a circle.
Marc Corney, Architect
Red Canoe Architecture, P. A.
