3DS Imports and Materials
Hello,
Once you've downloaded and converted a 3ds. file into an object file, is there anyway to make the object not one material. I downloaded some nice chairs from e-interior.net and they converted fine, only thing is, they're all one material. I want the fabric to be one material and I want the lges to be another material. This is what it looks like on the image before I download it, is there anyway to do this?????
Thank You
4 Replies 4
Hello Muddasick
Which version of ArchiCAd and which version of APi for 3DS Import do you use ?
I try with a seat at e-interior.net that i convert with 3DSKonverter and use with ArchiCAD 8.1. He works fine and i can change the parameters of the different materials define in the original 3DS object : one for the legs and an other for the rest of the seat without problem.
I'm using archicad 9, I use the convert 3ds file to object file add-on.
What do you use to convert the 3ds file to an object file????
I use an add-on specific for ArchiCAD 8,1 n German whom you can find at this place http://www.gshelp.de/CDownloads/downloads81import.html
Hi fmr, muddasick,
to have a correct material definitions for each sub-object of an object, you need to have the original 3ds element created or subdivided by more sub-objects...
I downloaded some nice chairs from...
So your chairs need to have the fabric as sub-obj of the chair, and the legs another sub-obj, and so on.
PWD
