3ds to gdl
I model this in 3ds max save as 3ds and convert it to gdl object I have good result in 3d but when I cut it (section or in 3d ) it empty any way in gdl to fill it ???
thank
4 REPLIES 4
It is because all mesh elements are treated as mesh not solid.
Best Regards,
Piotr
thank Piotr
but how I can convert form mesh to solid
thank
Have you tried the mesh to roof tool?
Help > ArchiCAD 13 Downloads
Mesh to Roof tool located under Goodies.
mesh to roof is only for mesh that build in AC not work for mesh from other application thank
