‎2015-11-18
11:14 AM
‎2023-05-24
01:01 PM
Rubia Torres
‎2015-11-18 05:40 PM
‎2015-11-19 12:12 PM
Piotr wrote:The what?
If the object is open - look for the "VALUES" in the parameter script.
You may simply comment the lines starting with: VALUES "a" [...]...VALUES "b" [...] and VALUES "zzyzx" [...]
Comment them by adding "!" in front.
Result will be the all of the 3 dims will not by constrained, but be warned - the object may not work correctly afterwords.
Best regards,
Piotr
‎2015-11-19 02:54 PM
