A problem with custom sizing a dl:ed object
So, um hi.
I got this problem where I downloaded a shelf ("Tall cabinet 1 fixed and 4 adjustable shelves without door 2100x600x400"), which I found by simply typing "shelf" to the search bar in the Object window.
Even after enabling Custom size, the shelf won't go beyond 300/800 in Dimension 1, 300/600 in D2 or 1800/2400 in D3. It always jumps to those values no matter what I type on the fields.
Is there a way to customise the values, or do I have to download another elsewhere and hope for the best?
Thank you!
3 Replies 3
If the object is open - look for the "VALUES" in the parameter script.
You may simply comment the lines starting with: VALUES "a" [...]...VALUES "b" [...] and VALUES "zzyzx" [...]
Comment them by adding "!" in front.
Result will be the all of the 3 dims will not by constrained, but be warned - the object may not work correctly afterwords.
Best regards,
Piotr
Best regards,
Piotr
The what? I'm afraid that's too advanced for me. Would you mind simplifying it?
David Maudlin
JustAStudent:
It looks like the object code is locked, so not accessible for changes. The size limits are what the author intended.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
