AC 12 and beyond Stock library parts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-08-15 02:14 AM
It seems that by the time I try and memorize the Hungarian 'hide and seek'
version of things, they will change them again.
Besides their building products "logic" is just killing me.
In a print out, I think I could handle it a lot easier.
At least I could put index tags on printed sheets.
Could this be done through the Database functions, and roughly how?
Never seen anything here on the forum regarding being able to do this, but thought I'd ask anyway.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-15 02:30 AM
In any version of archicad there is a pdf of the library. Go to the help menu when AC is open (or look in the documentation folder where it is installed) and you will find a pdf called Archicad Library Guide.
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-15 04:10 AM
Totally forgot about that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-16 08:00 PM
if you like the screen version. But I prefer a print version, so..
A couple of odd things I noticed.
1. After enlarging the full page view of the pdf, the small version of pages that show up on the right, (next to scroll bar)(a nice feature), could be a bit bigger, (50%).
Also would be nice to take into Excel because when using the option to say,
print two library pages to one 8.5x11 size sheet, the images are ok, and SOME of the indexing numbers are ok , however others are two small to read easily. Type setting was done with irregular sizes for some silly reason.
This I would assume I could fix (along with maybe other things) in Excel.
So. does anyone know of a way to import into Excel?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-17 04:57 AM
Unless you cut it up into images, but would be very time consuming
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-17 05:28 AM
Looks like I mishandled my words a bit.
What I meant was a way to get it out of AC's database into Excel for organizing a paper version and correcting sm vs large font used for indexing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-17 05:39 AM
it might be best to just request it from your ArchiCAD reseller?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-17 06:18 AM
If you do not have the "Query" command (SQL query) in your Calculate submenu, add it via the Work Environment.
In the query window, enter:
select name, location, preview_jpeg from libraryparts
and click Execute. The result will appear in your browser. There will be a number of entries with no library preview, as even macros will be listed.
You can either edit this HTML result, or convert/import it into Excel or a database.
Attached is the beginning of the browser view that resulted for me with the US library. Were I to have printed the output, it would have been 186 pages (!).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-17 07:38 PM
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-08-18 12:34 AM
The other thing is to use the Find option in all library-related dialogs, so that those things whose CSI category might be ambiguous - or which you don't want to dig for - are found instantly.
See screenshot.
