AC13 Libary guide pdf?
Erika Epstein
I recently noticed that under the HELP menu in AC13 the Library guide that has been there in past versions is missing.
Is it just me?
If not, will it be ready when you do the next library update?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika wrote:
Is it just me? ...
No, it's not only with you!
So, if you want to add some url just copy file(s) from your (default) ArchiCad 12 folder:
c:\Program Files\Graphisoft\ArchiCAD 12\WWWLinks to here c:\Program Files\Graphisoft\ArchiCAD 13\WWWLinks\
and new URLs will appear in the help menu.
btw. if oyu want to add some pdf_files in the same (help) menu just look in this folder: "c:\Program Files\Graphisoft\ArchiCAD 13\Documentation" and simply copy PDF files to this destin.,
The new help menu will be something like this:
Erika Epstein
Thanks, but I was trying to get GS to supply an AC13 one.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
