Robert Nichols
AC14 - Embedded lib objects not found.
So, the library is embedded, but the library objects are not showing up on the model (dots), and in Library Manager, the objects are only listed as missing.
I'm using Mac OS X. The file is shared, and I'm having this problem when opening the local copy. If I trash the local copy and get fresh data from the server, I see the objects again. But, after a save, close, and reopen, the local copy doesn't see the embedded lib objects again.
I must not understand the meaning of "embedded". Thought this wasn't supposed to happen...
Mac Studio, 32gb ram, ArchiCAD v26 (Apple Silicon) MacOS 13
0 Replies 0
