AC15 window casing placement issue
I did a lot of looking for similar topics before posting, so forgive me if this is something that has already been addressed. I recently switched from AC11 to AC15. In 11, when you placed a window or door you could say what kind of wall it was going in, in my case a stud wall with siding. The casing would be tight to the sheathing and interrupt the siding. Now that I'm using AC15 and its window library, I can't seem to figure out how to get the casing to reveal itself properly. It always seems to lap over the siding (see picture). Is there some setting I can change or something I'm missing to get the casing to look the way it's supposed to, or do I have to model the casing separately? The window is going into a wall that is a complex profile, but I've tried putting it in a composite wall and I have the same problem. Thanks for any help!
0 Replies 0
