AC18 - Options - Check surfaces
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-12-20 03:18 AM
‎2014-12-20
03:18 AM
"Missing textures might come from an unused rendering engine's surface parameters. Use the command
So, I can't find that command anywhere - I've searched for the phrase "Check Surfaces" in the AC18 Reference guide (no mention), this forum (no mention), and Google (no Archicad-relevant mention), to no avail.
Did the Check Surfaces tool get the flick when Building Materials arrived? But if so, what's the latest tool/advice for cleaning up these missing parameters?
Thanks for any guidance, folks.
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-20 04:49 AM
‎2014-12-20
04:49 AM
You may need to add the command to your work environment.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-20 08:46 AM
‎2014-12-20
08:46 AM
Done! Thanks Erich. Never would have worked that out by myself.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-21 12:22 AM
‎2014-12-21
12:22 AM
The tool is not in option but in option->elements attributes, long way down the list.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-21 03:26 PM
‎2014-12-21
03:26 PM
Ilder wrote:Yes!
Earlier this year I submitted a bug report about this as the warning in the Dialog gives the incorrect path.
And to put more information into the Help Center about this undocumented feature. AFAIK it is included to address legacy textures from the old Lightworks rendering settings.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-21 11:27 PM
‎2014-12-21
11:27 PM
...and the information box that pops up when you run the tool seems designed to confuse and discourage continuing - it made me wonder, "just what potentially devastating action am I agreeing to here? Perhaps I'd better cancel."
But then I thought, "No, this is Archicad. That's how all their warning messages sound."
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-21 11:31 PM
‎2014-12-21
11:31 PM
It's probably worth noting that, in my quest to remove all "missing objects from attributes" clean-up process, this tool did remove seven of the 18 textures that were flagged in the Library Loading Report window - so that did save me a bit of time, I guess.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-22 01:44 AM
‎2014-12-22
01:44 AM
Ilder wrote:Ilder, that doesn't seem to be the case in my (Australian) version of Archicad - see screep-capture. Is yours customised?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-12-22 09:23 AM
‎2014-12-22
09:23 AM
Not costumized,
i'm running INT version. Localization issue i guess.
