JGoode
AC19 Typing refresh issue
When typing into a text box on the object interface the text refreshes and highlights itself when pausing. Is there any way to fix this? maybe an ArchiCAD setting? I understand it is fixed in AC21 but is there any way to fix it in AC19?
Thanks
ArchiCAD 27
Windows 10
2 Replies 2
Palawat
Hi JGoode,
I think it has something to do with "Auto-Update Delay".
Go to Options > Work Environment > Dialog Boxes and Palettes > and set the "Auto-Update Delay" value to your preferred value (something higher than the default one, to give you more time to type in the UI).
HTH.
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
JGoode
Palawat wrote:
Hi JGoode,
HTH.
Excellent! Thank you very much.
ArchiCAD 27
Windows 10
