AC19 window and door labels not correct
Not sure what happened to my previous post ( did I do something wrong?) but question remains...wall and window with label and the size is wrong..should I be doing something?
1 REPLY 1
rgarand
Adjust your size and other attributes for the tag? They may have reverted back to the factory settings when you upgraded from 18-->19
Robert J. Garand
ArchiCAD USA 28-Build 3110 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
