KB-at-CWA
Archicad 27 Mac - Section Update Error
Hi everyone,
I am using Archicad 27 6060 on macOS Tahoe 26.3.
The issue I have is in section when I move an element such as a wall, the SOE that the wall had on the mesh stays where it is. Further to this, if I edit a wall in the 3D window and then go to the section the wall appears in its original position but when selected its hotspots are in the correct location. Please see the attached movies to explain the issue.
I am hoping it is just a setting that I have overlooked. I am open to any suggestion to any proposed solution resolves this. Currently the only thing that has worked is to close Archicad and reopen it.
Graphisoft Certified Archicad BIM Manager - AC6 to AC28 (not using AC29). macOS Tahoe
runxel
That's indeed very odd behavior. Have you tried to "Open & Repair"?
If that still happens this is case for the support and the devs.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
