‎2020-11-07
08:38 PM
‎2023-05-24
12:24 PM
Rubia Torres
Solved! Go to Solution.
‎2020-11-09 10:53 AM
‎2020-11-08 12:23 PM
‎2020-11-08 02:06 PM
Braza wrote:As You can see I set it in the correct way/position (I've created pink symbols to visualize it, just in case
When you place any door/window, you can define the interior/exterior side (Click on the little sun icon to define the exterior side).
You can have more info about placing doors and windows here.
‎2020-11-14 07:36 PM
Braza wrote:I think that I can skip the window placing part, because I'm doing it properly
Hi Figo,
I did saw your reference for the turn arrow and the sun.
I still mentioned it because it is common for new users get confused with this method of placing windows/doors.
When you place the window, you then select the exterior side. Not the window open swing.
Generally, doors and windows should open to the exterior. But in your case it is open to the interior. I think this is the reason why your window is not ending in the position you want.
I did a quick test with a custom made window and it is working as I describe.
Hope this helps.
