AC9 Teamwork: Window Tag Problem
We have a project in AC9 that is in Teamwork. The exterior elevations show the door and window tags, but these tags cannot be edited -- even when the project is opened with exclusive access as the Team Leader. They display a tooltip that says, "This element is not in your workspace". How do we fix this problem?
3 Replies 3
Jay,
Out of curriosity, are you using the label tool to tag the doors & windows in elevation, or is it the actual tag that is in the object? (are you checking the"label door" box under the Listing and Labeling menu?)
-Nathan
We are using a Label by checking "Label Door".
TomWaltz
The easy way is to unlabel (uncheck the box) then re-check it. It was a bug that I thought was fixed in a late service pack but cannot say for sure.
Tom Waltz
