ARCHICAD 22 - RFT option missing from pull down tool
Hi Support Team,
I need to import a Revit object into Archicad 22 or 23 but under the File -> Libraries & Objects is missing the ā€˜Import RFA as GDL Object’ menu.
Could you please help on this issue.
Kind regards,
Nita Guedes
1 REPLY 1
You need to download and install the converter from BIM6x.
There doesn't seem to be a 23 version yet.
https://bim6x.com/store
