‎2017-05-08 06:02 PM
‎2017-05-09 03:32 AM
‎2017-05-09 11:46 AM
Gerald wrote:Thank you Gerald Hoffman,
Hi Bryan,
I downloaded this to have a look and as you say there are walls and curtain walls set up with defaults for different Alucobond cladding systems. The walls are composite walls so they include the base wall structure and the cladding.
As far as I can see they are not objects you attach to exisiting walls. An easy way to get these into you project is copy and paste between the Alucobond pln file and your project.
‎2017-05-09 11:10 PM
Bryan91 wrote:Correct - you can't copy / paste in 3D window.
... I tried copy and paste earlier on and it didnt work. It seems to only work when you are in 2D floor plan and not in 3D view. That is at least what happen to me in ArchiCAD 20.
Thank you
