_Salmon
Add new functions to an object
I'm looking for a parametric curved rafter.
Anybody know something like the image?
It can be without 'anchor piece' but with circular section.
(As you can see in the attached image, using trussmaker i can do it but i need to do a gsm to each different rafter in the project.. i want to optimize this process with a single gsm.)
If not,
I'm looking some GDL developer who can modify the existing gsm in AC12 Library, adding first the circular section and if it would be posible a 'anchor piece'.
thanks
Since AC6
Win10pro / Intel Xeon E5-1650v4 / 128Gb DDR4 2400 MHz ECC REG / NVIDIA GeForce GTX 1080 / SSD Toshiba 512GB M.2
2 Replies 2
Hi Salmon,
Have you tried ArchiPIPE?
It also has connections for the pipes... maybe you can use it as anchors...
Hope this helps.
Ralph Wessel
Take a look at OBJECTiVE.
You can freely curve beams, repeatedly and in more than one axis (see the attached image). You can also make your own profiles and cut/rotate the objects in plan and section/elevation windows.
Ralph Wessel BArch
Central Innovation
