2017-12-02
01:12 AM
2024-03-06
12:16 PM
Aruzhan Hamar
2017-12-04 02:11 AM
2017-12-18 01:25 AM
Barry wrote:Thanks Barry, You are totally right.
I am not sure if this will solve your problem or not.
You will also need to load the Accessories Library.
This installs with the goodies but from memory it does not go in the same folder as the main Archicad Library.
So you either need to move it to the Archicad Library folder that is being loaded or load it separately.
From memory you will find it in the main Archicad program folder.
