tband
Adding Hard-Coded Properties to Custom Library Parts
Hello,
I would like to 'hardcode' custom property values within library objects (generated using the LPM), such that when an object is replaced with another, the property values are also replaced (currently they are retained). We are using the LPM to generate multiple housing types for use across a masterplan, and would like to schedule these types based on information such as type, size, bedrooms, tenure etc.
I have been able to generate listing properties which appear in the objects' description area, but it does not look like these can be scehduled.
Has anyone found a solution to this issue?
Operating system used: Mac Apple Silicon 12.4 Monteray
10 Replies 10
Lingwisyer
Guru
Unfortunate...
