Adjustable double hung window
Anyone use a double hung window where the height of the top and bottom sashes can be adjusted independently of the opening height? (eg a 1/3 to 2/3 top sash to bottom sash ratio) I've tried fiddling w/ gdl with some success, but more frustration..
Thanks
Dwight
I believe it can be done with WindowMaker, but if you aren't that picky, the metal awning window is right there and can be completely adjusted.......
Let's all sing the workaround song…
Dwight Atkinson
Aaron Bourgoin
CADimage Door/Window Builder does this
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
