Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Adjusting 3d opening Lines for Windows
Hi All
I have a problem in that I have a fixed window payne. I need to show 3d opening lines on other windows and doors and this setting gets changed in the model view section.
My problem is that the fixed window library part has an opening line which says FIX on it.
When I place the fixed window it shows this text and puts it in backwards.
Is there any way I can edit the window library part so that it takes that 'FIX' out?
My GDL skills are very limited.
Please see attached screen showing the window and problem
Regards
Trevor
iMac Intel
Mac OSX 10.6.4
ArchiCAD 13 Build 3600
2 REPLIES 2
David Maudlin
Trevor:
Please post the name of the window you are using.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I haven't noticed this on the windows in the INT library. Does South Africa have its own localised library version?
If the text is on the outside of the window, one thing you could try is to turn off 'Transparency' in the section/elevation settings, which should block the text from being seen from the inside.
