ArchiCAD 11 Corner window
ArchiCAD 10 has the corner window tool ... where is it on 11?
4 REPLIES 4
__archiben
same place as it is in 10.
sounds like you've managed to get your work environment a wee bit screwed up. open the work environment settings and go to the 'tool schemes' > 'toolbox...' tab and re-configure your toolbox.
(you use the corner window tool?! )
~/archiben
b e n f r o s t
Thanks ...
Thomas Holm
Ebbie wrote:
Thanks ...
Nice signature!
Where is it located? I can find a empty corner window but nothing with frames or glass.
