Converting library parts from older versions
I thought I read somewhere that if you use Ver 11 to open a project that had been started in Ver 10, without the Ver 10 library, then Archicad would substitute the equivalent library parts from Ver 11.
I can't make this work. Can it be done, or have I imagined this?
Keith
Archicad Ver 11 on Mac 0SX10.4.8
Eduardo Rolon
You need to download also the AC10 Subset library for the missing objects.
check here, under Library Archives
tr.graphisoftus.com/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
