Brockway
Is it possible to convert and import 3d Revit library parts for Archicad 23?
Hello. Is it possible to convert and import 3d Revit library parts for Archicad 23? It seems that this ability is available with newer Archicad versions, but I'm not sure if I can do it in Archicad 23 (on Mac). I am trying to import Simpson joist hangers and other similar objects for residential wood framing connectors.
Operating system used: Mac Intel-based Catalina
Setup info provided by author
1 Solution
Eduardo Rolon
Check here:
https://www.bim6x.com/rvt-rfa-addon
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Go to post
Eduardo Rolon
Check here:
AC29 US/INT -> AC08
another Moderator
Brockway
Thank you!
