‎2009-06-18 12:52 PM
‎2009-06-18 03:45 PM
‎2009-06-21 10:04 PM
‎2009-06-22 01:42 PM
Skappy wrote:10-15 Mb is much too large for an image in ArchiCAD. I'd recommend no more than about 1-2Mb max, and much less if possible. Reduce the number of pixels in the image and increase the jpg compression to reduce the size.
Hi, i need to place a fairly large picture into a restraunt, approx 10-15mb. I tried your suggestion and reloaded the library. So now i've got a blank canvas and it dosent show up in the render either. Any suggestions!! I've tried an indexed colour version and .pcx,.jpg,.tif, .png in rgb as well and nothing. I made the size of the picture same as original.
‎2009-06-24 08:50 AM
‎2009-06-24 07:22 PM
Skappy wrote:I'm not sure what is happening there. Mine renders fine without the frame!
...Also i discovered after trial and error that you need to turn the frame on otherwise it wont render. But then you need to make the frame material glass otherwise you wont see your image. This is the reason it was showing a blank canvas. All working fine now.
‎2009-06-25 11:32 AM
