Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Find the perfect object, manage libraries, create custom objects
Archibam Trees
I just downloaded th garden works library, and my archibam trees are generating without any leaves. I have the 'Leaves' option set to on in the objects settings. Any ideas?
Cheers
4 REPLIES 4
Show a picture of the values of your Parameters in the Parameters panel of the Object Settings Dialog with the Tree Object selected.
Also, state your AC version.
It works for me in AC11.
Thomas Holm
I don't know about Archibam trees, but I know there exists trees (for example some made for Artlantis) that are season-sensitive. Meaning in winter, they don't have leaves!
see also Graphisoft Green Line
http://www.graphisoft-muenchen.de/graphisoft-green-line-b%E4ume-und-pflanzen-f%FCr-archicad_tipp_265...
Thomas Holm
Thanks! I didn't know about those trees.
