Archicad 12 Door and windows not showing on plan or elevatio
I am pretty much a technical ignoramus. I am using A12 on Hp Pavilion dv 5 and the objects in the library do not appear when placed. They create space but are not showing in 2D.
Thanks for any help
annette
2 Replies 2
David Maudlin
Annette:
Check the Model View Options > Options for Construction Elements > Door Options. For more information with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "Model View Options" in the search box, in the results list will lead to detailed information.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David, that worked a treat! Thanks also for the advice re the signature. Thanks again for the speedy help.
Annette
