Archicad 18 has no detail in plan why? archicad 17 did
Dear all, remeber how archicad 16 and 17 changes to detailed plan when changing the scale to 1/50, like the doors on the plan show the thickness and frame, but on 18 it doesnt change , whenever i change the scale its stays the same , why is that?
2 Replies 2
That would probably depend on whether your objects have a "Scale sensitive" setting turned on.
And if you can't control it in the object parameters themselves then it might be controlled in the Model View Options.
