Archicad 19 Can`t change View Type
Hi, I don´t know why but currently I can´t change view types in Archicad...for example when selecting people contour and try to change from linear top view to front linear view y just stays fixed on top.
This happens with other object also.
Any ideas of what I´m missing or doing wrong?
Thanks
7 Replies 7
What is the name of the GDL Object that is showing this behaviour?
Thanks for your reply.
It happens in a lot of GDL objects, for example in every people contour or in bar stool under all parameters, chair style. (if you switch tabs to hairstyle tab it works....)etc...
Thanks
Could you show a screenshot? I don't exactly know where you are changing this setting and what is the result that is not correct.
Please post a screenshot.
Here is the screen shot.....
David Maudlin
mantrajt:
Make sure you have the latest update, there was a problem with OSX 10.11 (El Capitan). See Issues solved in ARCHICAD 19 Update 4011.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
mantrajt:
Thanks....I can`t believe that was it.....!!!
David Maudlin
In Work Environment > Company Standards and Schemes > Network and Update > enable Check for Updates to be sure of being on the latest build.
