Archicad 21 - missing library parts from all librarys on one PC
Josh Verran
Have a PC that has been working fine up until this morning.
Attempting to open any Archicad files, comes up with the notification that it is missing library parts from all libraries.
IE Archicad Library 21 and our own custom library.
Have tested files on other PCS and files/libraries work fine.
Have tested several files on the affected PC and all files have same library issue.
Through the file explorer I can access libraries fine.
Can remove libraries in the library manager and add new ones again, and still get issue.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
BoldArch
Hi Josh,
If you are using Teamwork, try deleting the problem libraries from your local data (must have all projects closed - Teamwork_Project_Local Data Manager), and then opening your project and select "reload and apply" from the library manager.
I had this issue yesterday with only one user. The other 8 users could access the libraries from the same project on different PCs.
If yours is not a teamwork issue, the above will be useless, so apologies in advance if this is the case.
Nathan B
Bold Architecture
https://boldmackay.com.au/
AC26 4019 INT FULL • Intel i9-9900 3.6GHz • 32 gb ram • Windows 10 Pro • NVIDIA GeForce RTX 2070 SUPER
AC19-26
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Josh,
Thank you for sharing the issue!
From your description, I believe either the libraries are corrupted/had some missing files, or there is something not correct with the ARCHICAD 21 on that particular machine only, as other machines do not have the same issue with this file. Based on this, I suggest trying the following steps:
- Please check the libraries in the problematic machine to see if they contain all the files. The easiest way to do it is to take a copy of the whole libraries' folders from a working machine and paste them into the problematic one.
You may want to paste these into a separate folder, delete all existing libraries in the file, and relink using the copied version.
- If the above step does not help, a repair/reinstallation of ARCHICAD may help
Let me know about the result of the test above! Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
