Find the perfect object, manage libraries, create custom objects
SOLVED!
Arrow keys to scroll thru attributes useless on AC26
Vinicius Lima
I have just migrated from AC25 to AC26, and the new search-bar in almost all instances of the software looks great... But, now, when you open an attribute window, it goes directly "selected" in the search-bar.
I don't understand why it was disabled to type "arrow-keys" in the keyboard to scroll up/down through the attributes, after or before typing any text in search-bar. Even that I've started using arrow-keys to reduce work in my mouse-arm (I developed an arm injury (tennis elbow) because of the massive work in computer), I realized a gain of productivity with this method. Sometimes I already know, that the attribute that I need, is just one or two attributes down/up of current one, and entering in the attribute window and type arrow-keys for that, is faster, better, and in my case, healthier . It now, become a wish for AC27.
- Vinícius Lima - user since Archicad 12
from Brazil
Apple MacBook Pro 16" 2023 | M2 Pro | 16Gb RAM | macOS Ventura 13.5.2
1 ACCEPTED SOLUTION
Solution
Gabor Almasi
Thank you for pointing this out.
It will be fixed in Archicad 27.
Regards,
Gabor
Gabor Almasi
Senior Product Manager
GRAPHISOFT
1 REPLY 1
Solution
Gabor Almasi
Regards,
Gabor
Gabor Almasi
GRAPHISOFT
