Parametric 2D window symbol
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-04-14
04:24 PM
- last edited on
2023-05-10
11:26 AM
by
Gordana Radonic
Hi, I'm looking for the simplest way to create a parametric/resizable 2D window symbol. I've attached an image of the symbol—ideally there would be parameters for window height, wall thickness, casing size, etc. Is this possible without spending a ton of time learning GDL scripting?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-04-14 05:06 PM
Without GDL, no.
Fortuantely for you this is pretty basic to implement.
all you'll need to know is how the Poly2 function works, and the transformation stack (add2, del, rot, etc...)
Look in the gdl documentation for :
Poly2
Line2
2D transformations
FILL
LINETYPE
All these a straightforward and easy to understand.
